Gentoo sul mio PC: xfce lifting
Re: Gentoo sul mio PC: xfce lifting
Messaggio da Zievatron »
conoscenza ha scritto:procedi con:
revdep-rebuild
emerge media-gfx/exiv2
riemergi "tango"
Sto procedendo, ma cos'è exiv2?
Finito. Ancora problemi:
make[3]: *** [dot_static] Errore 1
make[3]: Leaving directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/cmd/dot'
make[2]: *** [all-recursive] Errore 1
make[2]: Leaving directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/cmd'
make[1]: *** [all-recursive] Errore 1
make[1]: Leaving directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3'
make: *** [all] Errore 2
emake failed
 * ERROR: media-gfx/graphviz-2.26.3-r3 failed (compile phase):
 *   emake failed
 * Call stack:
 *          ebuild.sh, line   85:  Called src_compile
 *        environment, line 5180:  Called _eapi2_src_compile
 *   phase-helpers.sh, line  573:  Called die
 * The specific snippet of code:
 *   		emake || die "emake failed"
 * If you need support, post the output of 'emerge --info =media-gfx/graphviz-2.26.3-r3',
 * the complete build log and the output of 'emerge -pqv =media-gfx/graphviz-2.26.3-r3'.
 * The complete build log is located at '/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/temp/build.log'.
 * The ebuild environment file is located at '/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/temp/environment'.
 * S: '/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3'
>>> Failed to emerge media-gfx/graphviz-2.26.3-r3, Log file:
 * Messages for package media-gfx/graphviz-2.26.3-r3:
 *   emake failed
 * Call stack:
Zievatron ha scritto:Sto procedendo, ma cos'è exiv2?
Nel messaggio di errore precedente diceva:
* PLEASE PLEASE take note of this:
* Please make *sure* to run revdep-rebuild now
* Certain things on your system may have linked against a
* different version of exiv2 -- those things need to be
* recompiled. Sorry for the inconvenience!
...lancia "revdep-rebuild" e poi ri-emergi "exiv2"...
Sinceramente cosa contenga quel pacchetto non lo so. Dai:
eix media-gfx/exiv2
per saperlo. ;)
Zievatron ha scritto: Finito. Ancora problemi:
emake failed
 *   emake failed
 * Call stack:
 *   emake failed
 * Call stack:
revdep-rebuild
ritenta l'emersione di "tango"....
Zievatron ha scritto:Alla fine, l'unica e non usarlo mai più.
non usandolo rischi di trovarti un sistema compromesso da vecchi pacchetti che non ti servono più.
Gentoo non gestisce nulla automaticamente: questo il suo punto di forza! (Ovviamente se lo si sa usare).
Lui non cambia nemmeno una virgola se tu non vuoi... :D
Bello. Ma io come faccio a sapere quali pacchetti non servono più? E' lui che lo deve sapere! E se non servono più perchè sono da sostituire, mi sta bene che chieda il permesso per operare, ma se io gli dico di operare, l'operazione lui la deve fare completa di sostituzione, non a metà. Altrimenti mi spiazza e questo non è niente bene, è male. :s
è un circolo vizioso.
gli utenti di Gentoo sono, solitamente, sempre immersi tra documentazioni e guide: non sto scherzando.
Gentoo è un SO molto flessibile, ma questa flessibilità si paga stando sempre dietro ad ogni cosa. Molti non sono disposti a questo e passano ad altre distro precompilate. A meno che si faccia un patto con se stessi e ci si dica:"configuro tutto e poi non tocco più la parte di amministrazione del sistema". Questi sono casi rari.
Prima di tutto, quando fa il countdown devi capire cosa ti sta per cancellare. Se non sai cosa possa essere fermi tutto, controlli e nel caso procedi. Altrimenti lasci.
Seconda cosa: il fatto che non parta più la grafica non è detto che sia stata l'opzione --depclean. Può anche essere che qualcosa si sia aggiornato e qualcosa no... e questo punto il sistema non parte. Ma questo potrebbe succedere anche con altre distro (anche se le possibilità sono più rare in quanto solo Gentoo offre la possibilità di trattare pacchetto per pacchetto...).
conoscenza ha scritto:...
revdep-rebuild
Ancora errore:
emake failed
 *   emake failed
 * Call stack:
 *        environment, line 5191:  Called _eapi2_src_compile
 *   emake failed
 * Call stack:
conoscenza ha scritto:è un circolo vizioso.
Aaaarrgghh!!! :s
E' un po' troppo. Passi per una fase iniziale. Ma dopo io vorrei ridurre il tempo di amministrazione ad un minimo. Per aggiornare, o per installare un nuovo programma. Ma stare sempre a fare amministrazione di sistema no. E' troppo. xx(
... A meno che si faccia un patto con se stessi e ci si dica:"configuro tutto e poi non tocco più la parte di amministrazione del sistema". ...
Troppo drastico. Significa non fare più nessun aggiornamento e non installare più nessun altro programma.
Serve un compromesso ragionevole. Altrimenti è meglio lasciar perdere Gentoo.
Ah! Ma allora si può sospendere il cont-down? Come?
Quindi la doppia distro è sempre meglio averla. Anzi, per me, è proprio indispensabile. :)
mostra:
e
cat /var/tmp/portage/media-gfx/graphviz-2.26.3-r3/temp/build.log
Zievatron ha scritto:Aaaarrgghh!!! :s
Gentoo, come ogni distro ha i suoi pro e i suoi contro.
Io nei periodi intensi di università non la uso mai...Preferisco usare Fedora...
Zievatron ha scritto:Ah! Ma allora si può sospendere il cont-down? Come?
credo con qualsiasi tasto... space o invio dovrebbero interrompere...
Zievatron ha scritto:Quindi la doppia distro è sempre meglio averla. Anzi, per me, è proprio indispensabile. :)
agli inizi è una mano santa. però ricorda che esistono sempre le live e gli avvii in init3 ;)
Portage 2.1.10.49 (default/linux/amd64/10.0/desktop, gcc-4.5.3, glibc-2.14.1-r3, 2.6.37.6 x86_64)
                        System Settings
System uname: Linux-2.6.37.6-x86_64-AMD_Sempron-tm-_Processor_3200+-with-gentoo-2.0.3
Timestamp of tree: Tue, 24 Apr 2012 21:00:01 +0000
app-shells/bash:          4.2_p20
dev-java/java-config:     2.1.11-r3
dev-lang/python:          2.7.2-r3, 3.2.2
dev-util/cmake:           2.8.6-r4
dev-util/pkgconfig:       0.26
sys-apps/baselayout:      2.0.3
sys-apps/openrc:          0.9.8.4
sys-apps/sandbox:         2.5
sys-devel/autoconf:       2.13, 2.68
sys-devel/automake:       1.11.1
sys-devel/binutils:       2.21.1-r1
sys-devel/gcc:            4.5.3-r2
sys-devel/gcc-config:     1.5-r2
sys-devel/libtool:        2.4-r1
sys-devel/make:           3.82-r1
sys-kernel/linux-headers: 3.1 (virtual/os-headers)
sys-libs/glibc:           2.14.1-r3
Repositories: gentoo
ACCEPT_KEYWORDS="amd64"
ACCEPT_LICENSE="* -@EULA @EULA"
CBUILD="x86_64-pc-linux-gnu"
CFLAGS="-march=native -O2 -pipe"
CHOST="x86_64-pc-linux-gnu"
CONFIG_PROTECT="/etc /usr/share/gnupg/qualified.txt /var/lib/hsqldb"
CONFIG_PROTECT_MASK="/etc/ca-certificates.conf /etc/dconf /etc/env.d /etc/env.d/java/ /etc/fonts/fonts.conf /etc/gconf /etc/gentoo-release /etc/revdep-rebuild /etc/sandbox.d /etc/terminfo"
CXXFLAGS="-march=native -O2 -pipe"
DISTDIR="/usr/portage/distfiles"
FEATURES="assume-digests binpkg-logs distlocks ebuild-locks fixlafiles news parallel-fetch protect-owned sandbox sfperms strict unknown-features-warn unmerge-logs unmerge-orphans userfetch"
FFLAGS=""
GENTOO_MIRRORS="http://distfiles.gentoo.org"
LANG="it_IT.utf8"
LDFLAGS="-Wl,-O1 -Wl,--as-needed"
LINGUAS="it"
MAKEOPTS="-j2"
PKGDIR="/usr/portage/packages"
PORTAGE_CONFIGROOT="/"
PORTAGE_RSYNC_OPTS="--recursive --links --safe-links --perms --times --compress --force --whole-file --delete --stats --human-readable --timeout=180 --exclude=/distfiles --exclude=/local --exclude=/packages"
PORTAGE_TMPDIR="/var/tmp"
PORTDIR="/usr/portage"
PORTDIR_OVERLAY=""
SYNC="rsync://rsync.gentoo.org/gentoo-portage"
USE="X Xaw3d a52 aac aalib acl acpi alsa amd64 ao audiofile automount axpat bash-completion bcmath berkdb bluetooth branding bzip2 cairo cdda cddb cdparanoia cdr cgi cleartype cli consolekit cracklib crypt css cups curl custom-cflags custom-cpuopts custom-optimization cxx dbus device-mapper dga disk-partition djvu dri dso dts dv dvb dvd dvdr eds embedded emboss encode evo exif extras faac faad fam fastcgi fat ffmpeg fftw firefox flac floppy fontconfig foomaticdb fortran fuse gd gdbm gdu ggi gif gimp ginac glib glibc-omitfp glitz gls gnome gnutls gphoto2 gpm gps graphviz gsm gstreamer gtk hal hddtemp iconv icu imagemagick ipv6 java jbig jpeg jpeg2k kdrive lame lcms ldap libass libcaca libgda libnotify libv4l libv4l2 lm_sensors lzo mad matroska midi mjpeg mmx mng modules mono mp3 mp4 mpeg mpi mpi-threads mplayer mtp mudflap multilib musepack musicbrainz mysql nas ncurses network networkmanager nls nptl nptlonly ntfs ogg openal openexr opengl openmp optimized-qmake oss pam pango pch pcntl pcre pda pdf perl plasma png policykit posix ppds pppd prelude pulseaudio python qt3support qt4 raw readline scanner schroedinger sdl semantic-desktop session shorten sip smartcard smp sndfile speex spell sql sqlite sse sse2 ssl startup-notification static-libs subversion svg sysfs syslog tcl tcpd theora threads thunar tiff timidity tk truetype twolame udev unicode usb v4l v4l2 vcd vdr vorbis wapack wav webkit wmf wxwidgets x264 xcb xft xine xml xorg xpm xrandr xulrunner xv xvid xvmc zip zlib" ALSA_CARDS="ali5451 als4000 atiixp atiixp-modem bt87x ca0106 cmipci emu10k1x ens1370 ens1371 es1938 es1968 fm801 hda-intel intel8x0 intel8x0m maestro3 trident usb-audio via82xx via82xx-modem ymfpci" ALSA_PCM_PLUGINS="adpcm alaw asym copy dmix dshare dsnoop empty extplug file hooks iec958 ioplug ladspa lfloat linear meter mmap_emul mulaw multi null plug rate route share shm softvol" APACHE2_MODULES="actions alias auth_basic authn_alias authn_anon authn_dbm authn_default authn_file authz_dbm authz_default authz_groupfile authz_host authz_owner authz_user autoindex cache cgi cgid dav dav_fs dav_lock deflate dir disk_cache env expires ext_filter file_cache filter headers include info log_config logio mem_cache mime mime_magic negotiation rewrite setenvif speling status unique_id userdir usertrack vhost_alias" CALLIGRA_FEATURES="kexi words flow plan sheets stage tables krita karbon braindump" CAMERAS="ptp2" COLLECTD_PLUGINS="df interface irq load memory rrdtool swap syslog" ELIBC="glibc" GPSD_PROTOCOLS="ashtech aivdm earthmate evermore fv18 garmin garmintxt gpsclock itrax mtk3301 nmea ntrip navcom oceanserver oldstyle oncore rtcm104v2 rtcm104v3 sirf superstar2 timing tsip tripmate tnt ubx" INPUT_DEVICES="mouse keyboard evdev" KERNEL="linux" LCD_DEVICES="bayrad cfontz cfontz633 glk hd44780 lb216 lcdm001 mtxorb ncurses text" LINGUAS="it" PHP_TARGETS="php5-3" RUBY_TARGETS="ruby18" USERLAND="GNU" VIDEO_CARDS="radeon" XTABLES_ADDONS="quota2 psd pknock lscan length2 ipv4options ipset ipp2p iface geoip fuzzy condition tee tarpit sysrq steal rawnat logmark ipmark dhcpmac delude chaos account"
Unset:  CPPFLAGS, CTARGET, EMERGE_DEFAULT_OPTS, INSTALL_MASK, LC_ALL, PORTAGE_BUNZIP2_COMMAND, PORTAGE_COMPRESS, PORTAGE_COMPRESS_FLAGS, PORTAGE_RSYNC_EXTRA_OPTS, USE_PYTHON
E' enorme, non riesco a prenderlo dall'inizio:
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for dlfcn.h... yes
checking for objdir... .libs
checking if x86_64-pc-linux-gnu-gcc supports -fno-rtti -fno-exceptions... no
checking for x86_64-pc-linux-gnu-gcc option to produce PIC... -fPIC -DPIC
checking if x86_64-pc-linux-gnu-gcc PIC flag -fPIC -DPIC works... yes
checking if x86_64-pc-linux-gnu-gcc static flag -static works... yes
checking if x86_64-pc-linux-gnu-gcc supports -c -o file.o... yes
checking if x86_64-pc-linux-gnu-gcc supports -c -o file.o... (cached) yes
checking whether the x86_64-pc-linux-gnu-gcc linker (/usr/x86_64-pc-linux-gnu/bin/ld -m elf_x86_64) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking for shl_load... no
checking for shl_load in -ldld... no
checking for dlopen... no
checking for dlopen in -ldl... yes
checking whether a program can dlopen itself... yes
checking whether a statically linked program can dlopen itself... no
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
checking which extension is used for runtime loadable modules... .so
checking which variable specifies run-time module search path... LD_LIBRARY_PATH
checking for the default library search path... /lib /usr/lib /usr/local/lib /usr/x86_64-pc-linux-gnu/lib /usr/lib/gcc/x86_64-pc-linux-gnu/4.5.3/32 /usr/lib/gcc/x86_64-pc-linux-gnu/4.5.3 /usr/lib/gcc/x86_64-pc-linux-gnu/4.5.3/32 /usr/lib/gcc/x86_64-pc-linux-gnu/4.5.3 /usr/lib64/opengl/xorg-x11/lib /lib64 /usr/lib64 /usr/local/lib64 /lib32 /usr/lib32 /usr/local/lib32 /lib /usr/lib /usr/lib64/qt4 /usr/lib32/qt4 /usr/lib/qt4
checking for library containing dlopen... -ldl
checking for dlerror... yes
checking for shl_load... (cached) no
checking for shl_load in -ldld... (cached) no
checking for dld_link in -ldld... no
checking for _ prefix in compiled symbols... no
checking whether deplibs are loaded by dlopen... yes
checking for argz.h... yes
checking for error_t... yes
checking for argz_add... yes
checking for argz_append... yes
checking for argz_count... yes
checking for argz_create_sep... yes
checking for argz_insert... yes
checking for argz_next... yes
checking for argz_stringify... yes
checking if argz actually works... yes
checking whether libtool supports -dlopen/-dlpreopen... yes
checking for unistd.h... (cached) yes
checking for dl.h... no
checking for sys/dl.h... no
checking for dld.h... no
checking for mach-o/dyld.h... no
checking for dirent.h... yes
checking for closedir... yes
checking for opendir... yes
checking for readdir... yes
checking for strlcat... no
checking for strlcpy... no
configure: creating ./config.status
config.status: creating Makefile
config.status: creating config.h
config.status: executing depfiles commands
config.status: executing libtool commands
graphviz-2.26.3 will be compiled with the following:
options:
  cgraph:        No (disabled by default - experimental)
  digcola:       No (disabled)
  expat:         Yes
  fontconfig:    Yes
  freetype:      Yes
  glut:          Yes
  gts:           No (gts library not available)
  ipsepcola:     No (disabled by default - C++ portability issues)
  ltdl:          Yes
  ortho:         No (disabled by default - experimental)
  png:           Yes
  jpeg:          No (only required by internal libgd)
  sfdp:          Yes
  shared:        Yes
  static:        Yes
commands:
  dot:           Yes (always enabled)
  neato:         Yes (always enabled)
  fdp:           Yes (always enabled)
  circo:         Yes (always enabled)
  twopi:         Yes (always enabled)
  gvpr:          Yes (always enabled)
  lefty:         Yes
  smyrna:        No (disabled by default - experimental)
plugin libraries:
  dot_layout:    Yes (always enabled)
  neato_layout:  Yes (always enabled)
  core:          Yes (always enabled)
  devil:         No (disabled)
  gd:            Yes
  gdiplus:       No (disabled by default - Windows only)
  gdk_pixbuf:    No (disabled)
  ghostscript:   Yes
  glitz:         No (disabled by default - incomplete)
  gtk:           Yes
  lasi:          No (disabled)
  ming:          No (disabled by default - incomplete)
  pangocairo:    Yes
  quartz:        No (disabled by default - Mac only)
  rsvg:          No (disabled)
  visio:         No (disabled by default - experimental)
  xlib:          Yes
language extensions:
  gv_sharp:      No (disabled)
  gv_guile:      No (disabled)
  gv_io:         No (disabled by default - no swig support yet)
  gv_java:       No (missing header)
  gv_lua:        No (disabled)
  gv_ocaml:      No (disabled)
  gv_perl:       Yes
  gv_php:        No (disabled)
  gv_python:     Yes
  gv_python23:   No (disabled by default - for multiversion installs)
  gv_python24:   No (disabled by default - for multiversion installs)
  gv_python25:   No (disabled by default - for multiversion installs)
  gv_python26:   No (disabled by default - for multiversion installs)
  gv_R:          No (disabled)
  gv_ruby:       No (disabled)
  gv_tcl:        Yes
  tcldot:        Yes
  tclpathplan:   Yes
  gdtclft:       Yes
  tkspline:      Yes
>>> Source configured.
>>> Compiling source in /var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3 ...
make -j2
make  all-recursive
make[1]: Entering directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3'
Making all in libltdl
make[2]: Entering directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/libltdl'
make  all-am
make[3]: Entering directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/libltdl'
/bin/sh ./libtool  --tag=CC   --mode=compile x86_64-pc-linux-gnu-gcc -DHAVE_CONFIG_H -I.  -DLT_CONFIG_H='<config.h>' -DLTDL -I. -I. -Ilibltdl -I./libltdl -I./libltdl   -march=native -O2 -pipe -MT dlopen.lo -MD -MP -MF .deps/dlopen.Tpo -c -o dlopen.lo `test -f 'loaders/dlopen.c' || echo './'`loaders/dlopen.c
/bin/sh ./libtool  --tag=CC   --mode=compile x86_64-pc-linux-gnu-gcc -DHAVE_CONFIG_H -I.  -DLTDLOPEN=libltdlc -DLT_CONFIG_H='<config.h>' -DLTDL -I. -I. -Ilibltdl -I./libltdl -I./libltdl   -march=native -O2 -pipe -MT libltdlc_la-preopen.lo -MD -MP -MF .deps/libltdlc_la-preopen.Tpo -c -o libltdlc_la-preopen.lo `test -f 'loaders/preopen.c' || echo './'`loaders/preopen.c
libtool: compile:  x86_64-pc-linux-gnu-gcc -DHAVE_CONFIG_H -I. "-DLT_CONFIG_H=<config.h>" -DLTDL -I. -I. -Ilibltdl -I./libltdl -I./libltdl -march=native -O2 -pipe -MT dlopen.lo -MD -MP -MF .deps/dlopen.Tpo -c loaders/dlopen.c  -fPIC -DPIC -o .libs/dlopen.o
libtool: compile:  x86_64-pc-linux-gnu-gcc -DHAVE_CONFIG_H -I. -DLTDLOPEN=libltdlc "-DLT_CONFIG_H=<config.h>" -DLTDL -I. -I. -Ilibltdl -I./libltdl -I./libltdl -march=native -O2 -pipe -MT libltdlc_la-preopen.lo -MD -MP -MF .deps/libltdlc_la-preopen.Tpo -c loaders/preopen.c  -fPIC -DPIC -o .libs/libltdlc_la-preopen.o
libtool: compile:  x86_64-pc-linux-gnu-gcc -DHAVE_CONFIG_H -I. "-DLT_CONFIG_H=<config.h>" -DLTDL -I. -I. -Ilibltdl -I./libltdl -I./libltdl -march=native -O2 -pipe -MT dlopen.lo -MD -MP -MF .deps/dlopen.Tpo -c loaders/dlopen.c -o dlopen.o >/dev/null 2>&1
libtool: compile:  x86_64-pc-linux-gnu-gcc -DHAVE_CONFIG_H -I. -DLTDLOPEN=libltdlc "-DLT_CONFIG_H=<config.h>" -DLTDL -I. -I. -Ilibltdl -I./libltdl -I./libltdl -march=native -O2 -pipe -MT libltdlc_la-preopen.lo -MD -MP -MF .deps/libltdlc_la-preopen.Tpo -c loaders/preopen.c -o libltdlc_la-preopen.o >/dev/null 2>&1
mv -f .deps/dlopen.Tpo .deps/dlopen.Plo
/bin/sh ./libtool  --tag=CC   --mode=compile x86_64-pc-linux-gnu-gcc -DHAVE_CONFIG_H -I.  -DLTDLOPEN=libltdlc -DLT_CONFIG_H='<config.h>' -DLTDL -I. -I. -Ilibltdl -I./libltdl -I./libltdl   -march=native -O2 -pipe -MT libltdlc_la-lt__alloc.lo -MD -MP -MF .deps/libltdlc_la-lt__alloc.Tpo -c -o libltdlc_la-lt__alloc.lo `test -f 'lt__alloc.c' || echo './'`lt__alloc.c
libtool: compile:  x86_64-pc-linux-gnu-gcc -DHAVE_CONFIG_H -I. -DLTDLOPEN=libltdlc "-DLT_CONFIG_H=<config.h>" -DLTDL -I. -I. -Ilibltdl -I./libltdl -I./libltdl -march=native -O2 -pipe -MT libltdlc_la-lt__alloc.lo -MD -MP -MF .deps/libltdlc_la-lt__alloc.Tpo -c lt__alloc.c  -fPIC -DPIC -o .libs/libltdlc_la-lt__alloc.o
mv -f .deps/libltdlc_la-preopen.Tpo .deps/libltdlc_la-preopen.Plo
/bin/sh ./libtool  --tag=CC   --mode=compile x86_64-pc-linux-gnu-gcc -DHAVE_CONFIG_H -I.  -DLTDLOPEN=libltdlc -DLT_CONFIG_H='<config.h>' -DLTDL -I. -I. -Ilibltdl -I./libltdl -I./libltdl   -march=native -O2 -pipe -MT libltdlc_la-lt_dlloader.lo -MD -MP -MF .deps/libltdlc_la-lt_dlloader.Tpo -c -o libltdlc_la-lt_dlloader.lo `test -f 'lt_dlloader.c' || echo './'`lt_dlloader.c
libtool: compile:  x86_64-pc-linux-gnu-gcc -DHAVE_CONFIG_H -I. -DLTDLOPEN=libltdlc "-DLT_CONFIG_H=<config.h>" -DLTDL -I. -I. -Ilibltdl -I./libltdl -I./libltdl -march=native -O2 -pipe -MT libltdlc_la-lt__alloc.lo -MD -MP -MF .deps/libltdlc_la-lt__alloc.Tpo -c lt__alloc.c -o libltdlc_la-lt__alloc.o >/dev/null 2>&1
libtool: compile:  x86_64-pc-linux-gnu-gcc -DHAVE_CONFIG_H -I. -DLTDLOPEN=libltdlc "-DLT_CONFIG_H=<config.h>" -DLTDL -I. -I. -Ilibltdl -I./libltdl -I./libltdl -march=native -O2 -pipe -MT libltdlc_la-lt_dlloader.lo -MD -MP -MF .deps/libltdlc_la-lt_dlloader.Tpo -c lt_dlloader.c  -fPIC -DPIC -o .libs/libltdlc_la-lt_dlloader.o
mv -f .deps/libltdlc_la-lt__alloc.Tpo .deps/libltdlc_la-lt__alloc.Plo
/bin/sh ./libtool  --tag=CC   --mode=compile x86_64-pc-linux-gnu-gcc -DHAVE_CONFIG_H -I.  -DLTDLOPEN=libltdlc -DLT_CONFIG_H='<config.h>' -DLTDL -I. -I. -Ilibltdl -I./libltdl -I./libltdl   -march=native -O2 -pipe -MT libltdlc_la-lt_error.lo -MD -MP -MF .deps/libltdlc_la-lt_error.Tpo -c -o libltdlc_la-lt_error.lo `test -f 'lt_error.c' || echo './'`lt_error.c
libtool: compile:  x86_64-pc-linux-gnu-gcc -DHAVE_CONFIG_H -I. -DLTDLOPEN=libltdlc "-DLT_CONFIG_H=<config.h>" -DLTDL -I. -I. -Ilibltdl -I./libltdl -I./libltdl -march=native -O2 -pipe -MT libltdlc_la-lt_dlloader.lo -MD -MP -MF .deps/libltdlc_la-lt_dlloader.Tpo -c lt_dlloader.c -o libltdlc_la-lt_dlloader.o >/dev/null 2>&1
libtool: compile:  x86_64-pc-linux-gnu-gcc -DHAVE_CONFIG_H -I. -DLTDLOPEN=libltdlc "-DLT_CONFIG_H=<config.h>" -DLTDL -I. -I. -Ilibltdl -I./libltdl -I./libltdl -march=native -O2 -pipe -MT libltdlc_la-lt_error.lo -MD -MP -MF .deps/libltdlc_la-lt_error.Tpo -c lt_error.c  -fPIC -DPIC -o .libs/libltdlc_la-lt_error.o
mv -f .deps/libltdlc_la-lt_dlloader.Tpo .deps/libltdlc_la-lt_dlloader.Plo
/bin/sh ./libtool  --tag=CC   --mode=compile x86_64-pc-linux-gnu-gcc -DHAVE_CONFIG_H -I.  -DLTDLOPEN=libltdlc -DLT_CONFIG_H='<config.h>' -DLTDL -I. -I. -Ilibltdl -I./libltdl -I./libltdl   -march=native -O2 -pipe -MT libltdlc_la-ltdl.lo -MD -MP -MF .deps/libltdlc_la-ltdl.Tpo -c -o libltdlc_la-ltdl.lo `test -f 'ltdl.c' || echo './'`ltdl.c
libtool: compile:  x86_64-pc-linux-gnu-gcc -DHAVE_CONFIG_H -I. -DLTDLOPEN=libltdlc "-DLT_CONFIG_H=<config.h>" -DLTDL -I. -I. -Ilibltdl -I./libltdl -I./libltdl -march=native -O2 -pipe -MT libltdlc_la-lt_error.lo -MD -MP -MF .deps/libltdlc_la-lt_error.Tpo -c lt_error.c -o libltdlc_la-lt_error.o >/dev/null 2>&1
libtool: compile:  x86_64-pc-linux-gnu-gcc -DHAVE_CONFIG_H -I. -DLTDLOPEN=libltdlc "-DLT_CONFIG_H=<config.h>" -DLTDL -I. -I. -Ilibltdl -I./libltdl -I./libltdl -march=native -O2 -pipe -MT libltdlc_la-ltdl.lo -MD -MP -MF .deps/libltdlc_la-ltdl.Tpo -c ltdl.c  -fPIC -DPIC -o .libs/libltdlc_la-ltdl.o
mv -f .deps/libltdlc_la-lt_error.Tpo .deps/libltdlc_la-lt_error.Plo
/bin/sh ./libtool  --tag=CC   --mode=compile x86_64-pc-linux-gnu-gcc -DHAVE_CONFIG_H -I.  -DLTDLOPEN=libltdlc -DLT_CONFIG_H='<config.h>' -DLTDL -I. -I. -Ilibltdl -I./libltdl -I./libltdl   -march=native -O2 -pipe -MT libltdlc_la-slist.lo -MD -MP -MF .deps/libltdlc_la-slist.Tpo -c -o libltdlc_la-slist.lo `test -f 'slist.c' || echo './'`slist.c
libtool: compile:  x86_64-pc-linux-gnu-gcc -DHAVE_CONFIG_H -I. -DLTDLOPEN=libltdlc "-DLT_CONFIG_H=<config.h>" -DLTDL -I. -I. -Ilibltdl -I./libltdl -I./libltdl -march=native -O2 -pipe -MT libltdlc_la-slist.lo -MD -MP -MF .deps/libltdlc_la-slist.Tpo -c slist.c  -fPIC -DPIC -o .libs/libltdlc_la-slist.o
libtool: compile:  x86_64-pc-linux-gnu-gcc -DHAVE_CONFIG_H -I. -DLTDLOPEN=libltdlc "-DLT_CONFIG_H=<config.h>" -DLTDL -I. -I. -Ilibltdl -I./libltdl -I./libltdl -march=native -O2 -pipe -MT libltdlc_la-slist.lo -MD -MP -MF .deps/libltdlc_la-slist.Tpo -c slist.c -o libltdlc_la-slist.o >/dev/null 2>&1
mv -f .deps/libltdlc_la-slist.Tpo .deps/libltdlc_la-slist.Plo
/bin/sh ./libtool --tag=CC   --mode=compile x86_64-pc-linux-gnu-gcc -DHAVE_CONFIG_H -I.  -DLT_CONFIG_H='<config.h>' -DLTDL -I. -I. -Ilibltdl -I./libltdl -I./libltdl   -march=native -O2 -pipe -MT lt__strl.lo -MD -MP -MF .deps/lt__strl.Tpo -c -o lt__strl.lo lt__strl.c
libtool: compile:  x86_64-pc-linux-gnu-gcc -DHAVE_CONFIG_H -I. "-DLT_CONFIG_H=<config.h>" -DLTDL -I. -I. -Ilibltdl -I./libltdl -I./libltdl -march=native -O2 -pipe -MT lt__strl.lo -MD -MP -MF .deps/lt__strl.Tpo -c lt__strl.c  -fPIC -DPIC -o .libs/lt__strl.o
libtool: compile:  x86_64-pc-linux-gnu-gcc -DHAVE_CONFIG_H -I. "-DLT_CONFIG_H=<config.h>" -DLTDL -I. -I. -Ilibltdl -I./libltdl -I./libltdl -march=native -O2 -pipe -MT lt__strl.lo -MD -MP -MF .deps/lt__strl.Tpo -c lt__strl.c -o lt__strl.o >/dev/null 2>&1
mv -f .deps/lt__strl.Tpo .deps/lt__strl.Plo
/bin/sh ./libtool --tag=CC   --mode=link x86_64-pc-linux-gnu-gcc  -march=native -O2 -pipe -module -avoid-version -Wl,-O1 -Wl,--as-needed -o dlopen.la  dlopen.lo -ldl -ldl
libtool: link: x86_64-pc-linux-gnu-ar cru .libs/dlopen.a .libs/dlopen.o
libtool: link: x86_64-pc-linux-gnu-ranlib .libs/dlopen.a
libtool: link: ( cd ".libs" && rm -f "dlopen.la" && ln -s "../dlopen.la" "dlopen.la" )
libtool: compile:  x86_64-pc-linux-gnu-gcc -DHAVE_CONFIG_H -I. -DLTDLOPEN=libltdlc "-DLT_CONFIG_H=<config.h>" -DLTDL -I. -I. -Ilibltdl -I./libltdl -I./libltdl -march=native -O2 -pipe -MT libltdlc_la-ltdl.lo -MD -MP -MF .deps/libltdlc_la-ltdl.Tpo -c ltdl.c -o libltdlc_la-ltdl.o >/dev/null 2>&1
mv -f .deps/libltdlc_la-ltdl.Tpo .deps/libltdlc_la-ltdl.Plo
/bin/sh ./libtool --tag=CC   --mode=link x86_64-pc-linux-gnu-gcc  -march=native -O2 -pipe -no-undefined -dlpreopen dlopen.la  -Wl,-O1 -Wl,--as-needed -o libltdlc.la  libltdlc_la-preopen.lo libltdlc_la-lt__alloc.lo libltdlc_la-lt_dlloader.lo libltdlc_la-lt_error.lo libltdlc_la-ltdl.lo libltdlc_la-slist.lo lt__strl.lo -ldl
libtool: link: rm -f .libs/libltdlc.nm .libs/libltdlc.nmS .libs/libltdlc.nmT
libtool: link: (cd .libs && x86_64-pc-linux-gnu-gcc -march=native -O2 -pipe -c -fno-builtin  -fPIC -DPIC "libltdlcS.c")
libtool: link: rm -f ".libs/libltdlcS.c" ".libs/libltdlc.nm" ".libs/libltdlc.nmS" ".libs/libltdlc.nmT"
libtool: link: (cd .libs/libltdlc.lax/dlopen.a && x86_64-pc-linux-gnu-ar x "/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/libltdl/./.libs/dlopen.a")
libtool: link: x86_64-pc-linux-gnu-ar cru .libs/libltdlc.a .libs/libltdlc_la-preopen.o .libs/libltdlc_la-lt__alloc.o .libs/libltdlc_la-lt_dlloader.o .libs/libltdlc_la-lt_error.o .libs/libltdlc_la-ltdl.o .libs/libltdlc_la-slist.o .libs/lt__strl.o .libs/libltdlcS.o  .libs/libltdlc.lax/dlopen.a/dlopen.o
libtool: link: x86_64-pc-linux-gnu-ranlib .libs/libltdlc.a
libtool: link: rm -fr .libs/libltdlc.lax
libtool: link: ( cd ".libs" && rm -f "libltdlc.la" && ln -s "../libltdlc.la" "libltdlc.la" )
make[3]: Leaving directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/libltdl'
make[2]: Leaving directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/libltdl'
Making all in lib
make[2]: Entering directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib'
Making all in cdt
make[3]: Entering directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/cdt'
  CC     dtclose.lo
  CC     dtdisc.lo
  CC     dtextract.lo
  CC     dtflatten.lo
  CC     dthash.lo
  CC     dtlist.lo
  CC     dtmethod.lo
  CC     dtopen.lo
  CC     dtrenew.lo
  CC     dtrestore.lo
  CC     dtsize.lo
  CC     dtstat.lo
  CC     dtstrhash.lo
  CC     dttree.lo
  CC     dtview.lo
  CC     dtwalk.lo
  CCLD   libcdt.la
  CCLD   libcdt_C.la
make[3]: Leaving directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/cdt'
Making all in graph
make[3]: Entering directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/graph'
  CC     attribs.lo
  CC     agxbuf.lo
  CC     edge.lo
  CC     graph.lo
  CC     graphio.lo
  CC     lexer.lo
lexer.c: In function 'aglasterr':
lexer.c:513:10: warning: ignoring return value of 'fread', declared with attribute warn_unused_result
  CC     node.lo
  CC     parser.lo
  CC     refstr.lo
  CC     trie.lo
  CCLD   libgraph.la
  CCLD   libgraph_C.la
make[3]: Leaving directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/graph'
Making all in cgraph
make[3]: Entering directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/cgraph'
  CC     agerror.lo
  CC     agxbuf.lo
agerror.c: In function 'aglasterr':
agerror.c:45:10: warning: ignoring return value of 'fread', declared with attribute warn_unused_result
  CC     apply.lo
  CC     attr.lo
  CC     edge.lo
  CC     flatten.lo
  CC     graph.lo
  CC     grammar.lo
  CC     id.lo
  CC     imap.lo
  CC     io.lo
io.c:90:1: warning: initialization from incompatible pointer type
  CC     mem.lo
  CC     node.lo
  CC     obj.lo
  CC     pend.lo
  CC     rec.lo
  CC     refstr.lo
  CC     scan.lo
lex.aag.c:1503:16: warning: 'input' defined but not used
../../lib/cgraph/scan.l: In function 'aaglex':
../../lib/cgraph/scan.l:193:1: warning: ignoring return value of 'fwrite', declared with attribute warn_unused_result
  CC     subg.lo
  CC     utils.lo
  CC     write.lo
  CCLD   libcgraph.la
  CCLD   libcgraph_C.la
make[3]: Leaving directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/cgraph'
Making all in gd
make[3]: Entering directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/gd'
make[3]: Nessuna operazione da eseguire per «all».
make[3]: Leaving directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/gd'
Making all in pathplan
make[3]: Entering directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/pathplan'
  CC     cvt.lo
  CC     inpoly.lo
cvt.c:279:13: warning: 'append_bezier' defined but not used
  CC     route.lo
  CC     shortest.lo
shortest.c: In function 'loadtriangle':
shortest.c:537:8: warning: assuming signed overflow does not occur when assuming that (X + c) < X is always false
  CC     shortestpth.lo
  CC     solvers.lo
  CC     triang.lo
  CC     util.lo
  CC     visibility.lo
  CCLD   libpathplan_C.la
  CCLD   libpathplan.la
make[3]: Leaving directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/pathplan'
Making all in sfio
make[3]: Entering directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/sfio'
Making all in Sfio_f
make[4]: Entering directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/sfio/Sfio_f'
mkdir -p ../../../FEATURE
../../../iffe - set cc x86_64-pc-linux-gnu-gcc   : run ../../../lib/sfio/features/sfio > ../../../FEATURE/sfio
  CC     _sfclrerr.lo
  CC     _sfdlen.lo
  CC     _sfeof.lo
  CC     _sferror.lo
  CC     _sffileno.lo
  CC     _sfgetc.lo
  CC     _sfllen.lo
  CC     _sfputc.lo
  CC     _sfputd.lo
  CC     _sfputl.lo
  CC     _sfputm.lo
  CC     _sfputu.lo
  CC     _sfslen.lo
  CC     _sfstacked.lo
  CC     _sfulen.lo
  CC     _sfvalue.lo
  CCLD   libsfiof_C.la
make[4]: Leaving directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/sfio/Sfio_f'
make[4]: Entering directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/sfio'
  CC     sfclose.lo
  CC     sfclrlock.lo
sfclose.c: In function 'sfclose':
sfclose.c:91:3: warning: operation on 'f->endr' may be undefined
  CC     sfcvt.lo
  CC     sfdisc.lo
sfdisc.c: In function 'sfdisc':
sfdisc.c:66:3: warning: operation on 'f->endr' may be undefined
sfdisc.c:91:6: warning: operation on 'f->endr' may be undefined
sfdisc.c:102:3: warning: operation on 'f->endr' may be undefined
sfdisc.c:150:5: warning: operation on 'f->endr' may be undefined
  CC     sfdlen.lo
  CC     sfexcept.lo
  CC     sfexit.lo
sfexcept.c: In function '_sfexcept':
sfexcept.c:47:6: warning: operation on 'f->endr' may be undefined
sfexcept.c:108:6: warning: operation on 'f->endr' may be undefined
  CC     sfextern.lo
  CC     sffcvt.lo
  CC     sffilbuf.lo
  CC     sfflsbuf.lo
sffilbuf.c: In function '_sffilbuf':
sffilbuf.c:94:5: warning: operation on 'f->endr' may be undefined
sfflsbuf.c: In function '_sfflsbuf':
sfflsbuf.c:60:3: warning: operation on 'f->endr' may be undefined
sfflsbuf.c:93:6: warning: operation on 'f->endr' may be undefined
sfflsbuf.c:99:5: warning: operation on 'f->endr' may be undefined
  CC     sfgetd.lo
  CC     sfgetl.lo
sfgetd.c: In function 'sfgetd':
sfgetd.c:70:5: warning: operation on 'f->endr' may be undefined
sfgetl.c: In function 'sfgetl':
sfgetl.c:61:5: warning: operation on 'f->endr' may be undefined
  CC     sfgetm.lo
  CC     sfgetr.lo
sfgetm.c: In function 'sfgetm':
sfgetm.c:60:5: warning: operation on 'f->endr' may be undefined
sfgetr.c: In function 'sfgetr':
sfgetr.c:139:5: warning: operation on 'f->endr' may be undefined
  CC     sfgetu.lo
sfgetu.c: In function 'sfgetu':
sfgetu.c:59:5: warning: operation on 'f->endr' may be undefined
  CC     sfllen.lo
  CC     sfmode.lo
sfmode.c: In function '_sfcleanup':
sfmode.c:94:6: warning: operation on 'f->endr' may be undefined
sfmode.c: In function '_sfmode':
sfmode.c:563:5: warning: operation on 'f->endr' may be undefined
  CC     sfmove.lo
sfmove.c: In function 'sfmove':
sfmove.c:228:2: warning: operation on 'fr->endr' may be undefined
sfmove.c:230:6: warning: operation on 'fw->endr' may be undefined
sfmove.c:244:5: warning: operation on 'fr->endr' may be undefined
sfmove.c:246:2: warning: operation on 'fw->endr' may be undefined
sfmove.c:189:3: warning: ignoring return value of 'read', declared with attribute warn_unused_result
  CC     sfmutex.lo
  CC     sfnew.lo
  CC     sfnotify.lo
  CC     sfnputc.lo
  CC     sfopen.lo
sfnputc.c: In function 'sfnputc':
sfnputc.c:73:5: warning: operation on 'f->endr' may be undefined
  CC     sfpkrd.lo
  CC     sfpoll.lo
  CC     sfpool.lo
  CC     sfpopen.lo
sfpool.c: In function '_sfpdelete':
sfpool.c:203:2: warning: operation on 'f->endr' may be undefined
sfpool.c: In function 'sfpool':
sfpool.c:342:5: warning: operation on 'pf->endr' may be undefined
sfpool.c:343:5: warning: operation on 'f->endr' may be undefined
sfpool.c:350:2: warning: operation on 'f->endr' may be undefined
sfpool.c:354:2: warning: operation on 'pf->endr' may be undefined
  CC     sfprintf.lo
  CC     sfprints.lo
  CC     sfpurge.lo
  CC     sfputd.lo
sfpurge.c: In function 'sfpurge':
sfpurge.c:67:2: warning: operation on 'f->endr' may be undefined
sfpurge.c:86:5: warning: operation on 'f->endr' may be undefined
sfputd.c: In function '_sfputd':
sfputd.c:54:2: warning: operation on 'f->endr' may be undefined
sfputd.c:72:5: warning: operation on 'f->endr' may be undefined
sfputd.c:95:5: warning: operation on 'f->endr' may be undefined
  CC     sfputl.lo
  CC     sfputm.lo
sfputl.c: In function '_sfputl':
sfputl.c:80:5: warning: operation on 'f->endr' may be undefined
sfputm.c: In function '_sfputm':
sfputm.c:77:5: warning: operation on 'f->endr' may be undefined
  CC     sfputr.lo
  CC     sfputu.lo
sfputr.c: In function 'sfputr':
sfputr.c:112:5: warning: operation on 'f->endr' may be undefined
sfputu.c: In function '_sfputu':
sfputu.c:74:5: warning: operation on 'f->endr' may be undefined
  CC     sfraise.lo
  CC     sfrd.lo
sfraise.c: In function 'sfraise':
sfraise.c:51:6: warning: operation on 'f->endr' may be undefined
sfraise.c:66:5: warning: operation on 'f->endr' may be undefined
  CC     sfread.lo
sfread.c: In function 'sfread':
sfread.c:128:5: warning: operation on 'f->endr' may be undefined
  CC     sfreserve.lo
sfreserve.c: In function 'sfreserve':
sfreserve.c:139:5: warning: operation on 'f->endr' may be undefined
  CC     sfresize.lo
sfresize.c: In function 'sfresize':
sfresize.c:72:5: warning: operation on 'f->endr' may be undefined
  CC     sfscanf.lo
  CC     sfseek.lo
sfseek.c: In function 'sfseek':
sfseek.c:276:5: warning: operation on 'f->endr' may be undefined
  CC     sfset.lo
sfset.c: In function 'sfset':
sfset.c:84:5: warning: operation on 'f->endr' may be undefined
  CC     sfsetbuf.lo
  CC     sfsetfd.lo
sfsetbuf.c: In function 'sfsetbuf':
sfsetbuf.c:107:2: warning: operation on 'f->endr' may be undefined
sfsetbuf.c:332:5: warning: operation on 'f->endr' may be undefined
sfsetfd.c: In function 'sfsetfd':
sfsetfd.c:80:7: warning: operation on 'f->endr' may be undefined
sfsetfd.c:88:4: warning: operation on 'f->endr' may be undefined
sfsetfd.c:96:7: warning: operation on 'f->endr' may be undefined
sfsetfd.c:114:2: warning: operation on 'f->endr' may be undefined
  CC     sfsize.lo
sfsize.c: In function 'sfsize':
sfsize.c:101:5: warning: operation on 'f->endr' may be undefined
  CC     sfsk.lo
  CC     sfstack.lo
sfstack.c: In function 'sfstack':
sfstack.c:104:5: warning: operation on 'f1->endr' may be undefined
sfstack.c:105:5: warning: operation on 'f2->endr' may be undefined
  CC     sfstrtod.lo
  CC     sfswap.lo
sfswap.c: In function 'sfswap':
sfswap.c:61:3: warning: operation on 'f1->endr' may be undefined
sfswap.c:111:2: warning: operation on 'f1->endr' may be undefined
sfswap.c:115:5: warning: operation on 'f2->endr' may be undefined
  CC     sfsync.lo
sfsync.c: In function 'sfsync':
sfsync.c:147:2: warning: operation on 'f->endr' may be undefined
  CC     sftable.lo
  CC     sftell.lo
  CC     sftmp.lo
  CC     sfungetc.lo
  CC     sfvprintf.lo
sfungetc.c: In function 'sfungetc':
sfungetc.c:78:2: warning: operation on 'f->endr' may be undefined
sfungetc.c:103:5: warning: operation on 'f->endr' may be undefined
sfvprintf.c: In function 'sfvprintf':
sfvprintf.c:408:6: warning: operation on 'f->endr' may be undefined
sfvprintf.c:1063:5: warning: operation on 'f->endr' may be undefined
  CC     sfvscanf.lo
sfvscanf.c: In function 'sfvscanf':
sfvscanf.c:418:6: warning: operation on 'f->endr' may be undefined
sfvscanf.c:803:5: warning: operation on 'f->endr' may be undefined
  CC     sfwr.lo
  CC     sfwrite.lo
sfwrite.c: In function 'sfwrite':
sfwrite.c:149:5: warning: operation on 'f->endr' may be undefined
  CCLD   libsfio_C.la
make[4]: Leaving directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/sfio'
make[3]: Leaving directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/sfio'
Making all in vmalloc
make[3]: Entering directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/vmalloc'
mkdir -p ../../FEATURE
../../iffe - set cc x86_64-pc-linux-gnu-gcc   : run ../../lib/vmalloc/features/vmalloc > ../../FEATURE/vmalloc
  CC     vmbest.lo
  CC     malloc.lo
  CC     vmclear.lo
  CC     vmclose.lo
  CC     vmdcheap.lo
  CC     vmdebug.lo
  CC     vmdisc.lo
  CC     vmexit.lo
  CC     vmlast.lo
  CC     vmopen.lo
  CC     vmpool.lo
  CC     vmprivate.lo
  CC     vmprofile.lo
  CC     vmregion.lo
  CC     vmsegment.lo
  CC     vmset.lo
  CC     vmstat.lo
vmstat.c: In function 'vmstat':
vmstat.c:75:4: warning: dereferencing type-punned pointer will break strict-aliasing rules
  CC     vmstrdup.lo
  CC     vmtrace.lo
  CC     vmwalk.lo
  CCLD   libvmalloc_C.la
make[3]: Leaving directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/vmalloc'
Making all in ast
make[3]: Entering directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/ast'
  CC     chresc.lo
  CC     pathpath.lo
  CC     chrtoi.lo
  CC     error.lo
  CC     fmtbuf.lo
  CC     fmtesc.lo
  CC     pathaccess.lo
  CC     pathbin.lo
  CC     pathcanon.lo
  CC     pathcat.lo
  CC     pathexists.lo
  CC     pathfind.lo
  CC     pathgetlink.lo
  CC     strcopy.lo
  CC     stresc.lo
  CC     strmatch.lo
  CC     strton.lo
  CC     strerror.lo
  CCLD   libast_C.la
make[3]: Leaving directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/ast'
Making all in vpsc
make[3]: Entering directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/vpsc'
make[3]: Leaving directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/vpsc'
Making all in rbtree
make[3]: Entering directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/rbtree'
  CC     misc.lo
  CC     red_black_tree.lo
  CC     stack.lo
  CCLD   librbtree_C.la
make[3]: Leaving directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/rbtree'
Making all in ortho
make[3]: Entering directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/ortho'
make[3]: Leaving directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/ortho'
Making all in sparse
make[3]: Entering directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/sparse'
  CC     SparseMatrix.lo
  CCLD   libsparse_C.la
make[3]: Leaving directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/sparse'
Making all in patchwork
make[3]: Entering directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/patchwork'
  CC     patchwork.lo
  CC     patchworkinit.lo
patchwork.c:142:13: warning: 'printer' defined but not used
  CCLD   libpatchwork_C.la
make[3]: Leaving directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/patchwork'
Making all in expr
make[3]: Entering directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/expr'
  CC     excc.lo
  CC     excontext.lo
  CC     exdata.lo
  CC     exerror.lo
  CC     exeval.lo
  CC     exexpr.lo
  CC     exlexname.lo
exeval.c: In function 'eval':
exeval.c:910:14: warning: 'r.integer' may be used uninitialized in this function
  CC     exopen.lo
  CC     exrewind.lo
  CC     extoken.lo
  CC     extype.lo
  CC     exzero.lo
  CC     exparse.lo
  CCLD   libexpr_C.la
make[3]: Leaving directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/expr'
Making all in common
make[3]: Entering directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/common'
  CC     arrows.lo
  CC     colxlate.lo
  CC     fontmetrics.lo
  CC     args.lo
  CC     memory.lo
  CC     globals.lo
  CC     htmllex.lo
  CC     htmlparse.lo
  CC     htmltable.lo
  CC     input.lo
  CC     pointset.lo
  CC     postproc.lo
  CC     routespl.lo
  CC     splines.lo
  CC     psusershape.lo
  CC     timing.lo
  CC     labels.lo
  CC     ns.lo
  CC     shapes.lo
  CC     utils.lo
  CC     geom.lo
  CC     output.lo
  CC     emit.lo
emit.c: In function 'xdotBB':
emit.c:2092:12: warning: 'fontsize' may be used uninitialized in this function
emit.c:2093:11: warning: 'fontname' may be used uninitialized in this function
  CCLD   libcommon_C.la
make[3]: Leaving directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/common'
Making all in pack
make[3]: Entering directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/pack'
  CC     pack.lo
  CC     ccomps.lo
pack.c: In function 'putGraphs':
pack.c:913:12: warning: 'pts' may be used uninitialized in this function
  CCLD   libpack_C.la
make[3]: Leaving directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/pack'
Making all in xdot
make[3]: Entering directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/xdot'
  CC     xdot.lo
  CCLD   libxdot.la
  CCLD   libxdot_C.la
make[3]: Leaving directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/xdot'
Making all in gvc
make[3]: Entering directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/gvc'
  CC     gvrender.lo
  CC     gvlayout.lo
  CC     gvdevice.lo
  CC     gvloadimage.lo
  CC     gvcontext.lo
  CC     gvjobs.lo
  CC     gvevent.lo
  CC     gvplugin.lo
  CC     gvconfig.lo
  CC     gvtextlayout.lo
  CC     gvusershape.lo
  CC     gvc.lo
  CCLD   libgvc.la
  CCLD   libgvc_C.la
make[3]: Leaving directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/gvc'
Making all in ingraphs
make[3]: Entering directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/ingraphs'
  CC     ingraphs.lo
ingraphs.c: In function 'new_ing':
ingraphs.c:115:15: warning: assignment from incompatible pointer type
  CCLD   libingraphs_C.la
make[3]: Leaving directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/ingraphs'
Making all in topfish
make[3]: Entering directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/topfish'
make[3]: Leaving directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/topfish'
Making all in glcomp
make[3]: Entering directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/glcomp'
make[3]: Leaving directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/glcomp'
Making all in circogen
make[3]: Entering directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/circogen'
  CC     circularinit.lo
  CC     nodelist.lo
  CC     block.lo
  CC     edgelist.lo
  CC     circular.lo
  CC     deglist.lo
  CC     blocktree.lo
  CC     blockpath.lo
  CC     circpos.lo
  CC     nodeset.lo
  CCLD   libcircogen_C.la
make[3]: Leaving directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/circogen'
Making all in dotgen
make[3]: Entering directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/dotgen'
  CC     acyclic.lo
  CC     class1.lo
  CC     class2.lo
  CC     cluster.lo
  CC     compound.lo
  CC     conc.lo
  CC     decomp.lo
  CC     fastgr.lo
  CC     flat.lo
  CC     dotinit.lo
  CC     mincross.lo
  CC     position.lo
mincross.c: In function 'mincross.clone.11':
mincross.c:551:9: warning: 'maxthispass' may be used uninitialized in this function
  CC     rank.lo
  CC     sameport.lo
  CC     dotsplines.lo
  CC     aspect.lo
  CCLD   libdotgen_C.la
make[3]: Leaving directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/dotgen'
Making all in fdpgen
make[3]: Entering directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/fdpgen'
  CC     dbg.lo
  CC     comp.lo
  CC     grid.lo
  CC     fdpinit.lo
  CC     layout.lo
  CC     tlayout.lo
  CC     xlayout.lo
  CC     clusteredges.lo
  CCLD   libfdpgen_C.la
make[3]: Leaving directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/fdpgen'
Making all in neatogen
make[3]: Entering directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/neatogen'
  CC     adjust.lo
  CC     circuit.lo
  CC     edges.lo
adjust.c: In function 'removeOverlapWith':
adjust.c:997:9: warning: 'ret' may be used uninitialized in this function
  CC     geometry.lo
  CC     heap.lo
  CC     hedges.lo
  CC     info.lo
  CC     neatoinit.lo
  CC     legal.lo
  CC     lu.lo
  CC     matinv.lo
  CC     memory.lo
  CC     poly.lo
  CC     printvis.lo
  CC     site.lo
  CC     solve.lo
  CC     neatosplines.lo
  CC     stuff.lo
neatosplines.c: In function '_spline_edges':
neatosplines.c:757:15: warning: unused variable 'rtr'
  CC     voronoi.lo
voronoi.c: In function 'voronoi':
voronoi.c:29:11: warning: 'newintstar.x' may be used uninitialized in this function
voronoi.c:29:11: warning: 'newintstar.y' may be used uninitialized in this function
  CC     stress.lo
  CC     kkutils.lo
stress.c: In function 'mdsModel':
stress.c:1373:12: warning: 'delta' may be used uninitialized in this function
  CC     matrix_ops.lo
  CC     embed_graph.lo
  CC     dijkstra.lo
  CC     conjgrad.lo
  CC     pca.lo
  CC     closest.lo
  CC     bfs.lo
  CC     constraint.lo
  CC     quad_prog_solve.lo
  CC     smart_ini_x.lo
  CC     constrained_majorization.lo
  CC     opt_arrangement.lo
  CC     overlap.lo
  CC     call_tri.lo
  CC     compute_hierarchy.lo
  CC     delaunay.lo
  CC     multispline.lo
  CCLD   libneatogen_C.la
make[3]: Leaving directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/neatogen'
Making all in twopigen
make[3]: Entering directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/twopigen'
  CC     twopiinit.lo
  CC     circle.lo
  CCLD   libtwopigen_C.la
make[3]: Leaving directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/twopigen'
Making all in sfdpgen
make[3]: Entering directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/sfdpgen'
  CC     sfdpinit.lo
  CC     spring_electrical.lo
sfdpinit.c: In function 'sfdp_init_graph':
sfdpinit.c:71:9: warning: unused variable 'temp'
  CC     LinkedList.lo
  CC     sparse_solve.lo
  CC     post_process.lo
  CC     QuadTree.lo
  CC     Multilevel.lo
  CC     PriorityQueue.lo
  CCLD   libsfdpgen_C.la
make[3]: Leaving directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/sfdpgen'
Making all in osage
make[3]: Entering directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/osage'
  CC     osageinit.lo
  CCLD   libosage_C.la
make[3]: Leaving directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/osage'
Making all in gvpr
make[3]: Entering directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/gvpr'
  CC     mkdefs.o
  CCLD   mkdefs
./mkdefs gdefs.h < ../../lib/gvpr/gprdata
  CC     actions.lo
  CC     compile.lo
compile.c:78:1: warning: initialization from incompatible pointer type
actions.c: In function 'sfioWrite':
actions.c:574:17: warning: 'saveio' may be used uninitialized in this function
compile.c: In function 'setval':
compile.c:1480:21: warning: array subscript is below array bounds
actions.c: In function 'colorx':
actions.c:1263:9: warning: 'alpha' may be used uninitialized in this function
compile.c: In function 'getval':
compile.c:624:14: warning: 'v.integer' may be used uninitialized in this function
  CC     gvpr.lo
gvpr.c: In function 'travDFS':
gvpr.c:620:13: warning: comparison of distinct pointer types lacks a cast
  CC     gprstate.lo
  CC     parse.lo
  CC     queue.lo
  CCLD   libgvpr_C.la
  CCLD   libgvpr.la
make[3]: Leaving directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib/gvpr'
make[3]: Entering directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib'
make[3]: Nessuna operazione da eseguire per «all-am».
make[3]: Leaving directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib'
make[2]: Leaving directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/lib'
Making all in plugin
make[2]: Entering directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/plugin'
Making all in core
make[3]: Entering directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/plugin/core'
  CC     gvplugin_core.lo
  CC     gvrender_core_dot.lo
  CC     gvrender_core_fig.lo
  CC     gvrender_core_map.lo
  CC     gvrender_core_ps.lo
  CC     gvrender_core_svg.lo
  CC     gvrender_core_tk.lo
  CC     gvrender_core_vml.lo
  CC     gvloadimage_core.lo
  CCLD   libgvplugin_core.la
  CCLD   libgvplugin_core_C.la
make[3]: Leaving directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/plugin/core'
Making all in devil
make[3]: Entering directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/plugin/devil'
make[3]: Leaving directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/plugin/devil'
Making all in gd
make[3]: Entering directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/plugin/gd'
  CC     gvrender_gd.lo
  CC     gvplugin_gd.lo
  CC     gvrender_gd_vrml.lo
  CC     gvtextlayout_gd.lo
  CC     gvloadimage_gd.lo
  CC     gvdevice_gd.lo
  CCLD   libgvplugin_gd.la
  CCLD   libgvplugin_gd_C.la
make[3]: Leaving directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/plugin/gd'
Making all in gdk_pixbuf
make[3]: Entering directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/plugin/gdk_pixbuf'
make[3]: Leaving directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/plugin/gdk_pixbuf'
Making all in gdiplus
make[3]: Entering directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/plugin/gdiplus'
make[3]: Leaving directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/plugin/gdiplus'
Making all in glitz
make[3]: Entering directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/plugin/glitz'
make[3]: Leaving directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/plugin/glitz'
Making all in gs
make[3]: Entering directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/plugin/gs'
  CC     gvplugin_gs.lo
  CC     gvloadimage_gs.lo
  CCLD   libgvplugin_gs_C.la
  CCLD   libgvplugin_gs.la
make[3]: Leaving directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/plugin/gs'
Making all in gtk
make[3]: Entering directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/plugin/gtk'
  CC     gvplugin_gtk.lo
  CC     gvdevice_gtk.lo
  CC     support.lo
In file included from /usr/include/gtk-2.0/gtk/gtk.h:234:0,
                 from support.c:17:
/usr/include/gtk-2.0/gtk/gtkitemfactory.h:47:1: warning: function declaration isn't a prototype
                 from gvdevice_gtk.c:34:
  CC     interface.lo
  CC     callbacks.lo
                 from interface.c:18:
                 from callbacks.c:21:
  CCLD   libgvplugin_gtk.la
  CCLD   libgvplugin_gtk_C.la
make[3]: Leaving directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/plugin/gtk'
Making all in lasi
make[3]: Entering directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/plugin/lasi'
make[3]: Leaving directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/plugin/lasi'
Making all in ming
make[3]: Entering directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/plugin/ming'
make[3]: Leaving directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/plugin/ming'
Making all in pango
make[3]: Entering directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/plugin/pango'
  CC     gvplugin_pango.lo
  CC     gvrender_pango.lo
  CC     gvtextlayout_pango.lo
  CC     gvloadimage_pango.lo
  CCLD   libgvplugin_pango_C.la
  CCLD   libgvplugin_pango.la
make[3]: Leaving directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/plugin/pango'
Making all in quartz
make[3]: Entering directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/plugin/quartz'
make[3]: Leaving directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/plugin/quartz'
Making all in rsvg
make[3]: Entering directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/plugin/rsvg'
make[3]: Leaving directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/plugin/rsvg'
Making all in visio
make[3]: Entering directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/plugin/visio'
make[3]: Leaving directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/plugin/visio'
Making all in xlib
make[3]: Entering directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/plugin/xlib'
  CC     gvdevice_xlib.lo
  CC     gvplugin_xlib.lo
cp ../../plugin/xlib/vimdot.sh vimdot
chmod +x vimdot
  CCLD   libgvplugin_xlib_C.la
  CCLD   libgvplugin_xlib.la
make[3]: Leaving directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/plugin/xlib'
Making all in dot_layout
make[3]: Entering directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/plugin/dot_layout'
  CC     gvplugin_dot_layout.lo
  CC     gvlayout_dot_layout.lo
  CCLD   libgvplugin_dot_layout.la
  CCLD   libgvplugin_dot_layout_C.la
make[3]: Leaving directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/plugin/dot_layout'
Making all in neato_layout
make[3]: Entering directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/plugin/neato_layout'
  CC     gvplugin_neato_layout.lo
  CC     gvlayout_neato_layout.lo
  CCLD   libgvplugin_neato_layout_C.la
  CCLD   libgvplugin_neato_layout.la
make[3]: Leaving directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/plugin/neato_layout'
make[3]: Entering directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/plugin'
make[3]: Leaving directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/plugin'
make[2]: Leaving directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/plugin'
Making all in cmd
make[2]: Entering directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/cmd'
Making all in dot
make[3]: Entering directory `/var/tmp/portage/media-gfx/graphviz-2.26.3-r3/work/graphviz-2.26.3/cmd/dot'
  CC     dot-dot.o
  CC     dot-no_builtins.o
  CC     dot_static-dot.o
  CC     dot_static-dot_builtins.o
  CCLD   dot
  CCLD   dot_static
../../plugin/gd/.libs/libgvplugin_gd_C.a(gvrender_gd.o): In function `gdgen_end_page':
gvrender_gd.c:(.text+0x1aa): undefined reference to `gdImageGd2'
../../plugin/gd/.libs/libgvplugin_gd_C.a(gvdevice_gd.o): In function `gd_format':
gvdevice_gd.c:(.text+0x1f5): undefined reference to `gdImageGd2'
collect2: ld returned 1 exit status
emake failed
 *   emake failed
 * Call stack:
revdep-rebuild
completa tutto senza errori?
