Gentoo: Aggiornamento in difficoltà
Re: Gentoo: Aggiornamento in difficoltà
mi fai vedere:
locale
locale -a
Messaggio da Zievatron »
Ecco:
darkstar / # locale
LANG=it_IT.utf8
LC_CTYPE="it_IT.utf8"
LC_NUMERIC="it_IT.utf8"
LC_TIME="it_IT.utf8"
LC_COLLATE=C
LC_MONETARY="it_IT.utf8"
LC_MESSAGES="it_IT.utf8"
LC_PAPER="it_IT.utf8"
LC_NAME="it_IT.utf8"
LC_ADDRESS="it_IT.utf8"
LC_TELEPHONE="it_IT.utf8"
LC_MEASUREMENT="it_IT.utf8"
LC_IDENTIFICATION="it_IT.utf8"
LC_ALL=
darkstar / # locale -a
C
POSIX
it_IT.utf8
Provando a fare un nuovo aggiornamento, dopo aver riemerso portage, come suggerito dopo la sincronizzazione, è andata così:
darkstar / # emerge -DNu world
!!! The ebuild selected to satisfy ">=media-libs/mesa-7.8_rc[nptl=]" has unmet requirements.
- media-libs/mesa-8.0.3::gentoo USE="classic egl gallium llvm (multilib) nptl shared-glapi xvmc -bindist -d3d -debug -g3dvl -gbm -gles1 -gles2 -openvg -osmesa -pax_kernel -pic (-selinux) -shared-dricore -vdpau (-wayland) -xa" VIDEO_CARDS="radeon -i915 -i965 -intel -nouveau -r100 -r200 -r300 -r600 -vmware"
  The following REQUIRED_USE flag constraints are unsatisfied:
    xvmc? ( g3dvl )
  The above constraints are a subset of the following complete expression:
    d3d? ( gallium ) g3dvl? ( gallium ) llvm? ( gallium ) openvg? ( egl gallium ) gbm? ( shared-glapi ) g3dvl? ( any-of ( vdpau xvmc ) ) vdpau? ( g3dvl ) xa? ( gallium ) xvmc? ( g3dvl ) video_cards_intel? ( any-of ( classic gallium ) ) video_cards_i915? ( any-of ( classic gallium ) ) video_cards_i965? ( classic ) video_cards_nouveau? ( any-of ( classic gallium ) ) video_cards_radeon? ( any-of ( classic gallium ) ) video_cards_r100? ( classic ) video_cards_r200? ( classic ) video_cards_r300? ( gallium ) video_cards_r600? ( gallium ) video_cards_vmware? ( gallium )
(dependency required by "x11-base/xorg-server-1.12.2" [ebuild])
(dependency required by "@selected" [set])
(dependency required by "@world" [argument])
Cosa mi sta chiedendo di fare? :?
Devo aggiungere le USE in rosso?
EDIT:
Ho aggiunto queste USE, che erano in rosso
E poi ho riprovato.
Mi ha dato lo stesso messaggio, solo che alla fine, le tre righe "(dependency required by ...) sono cambiate così:
(dependency required by "x11-libs/qt-gui-4.8.1-r1[egl]" [ebuild])
(dependency required by "x11-libs/qt-core-4.8.1-r3[qt3support]" [installed])
(dependency required by "app-text/poppler-0.18.4-r1[qt4]" [installed])
(dependency required by "net-print/cups-1.5.2-r4" [installed])
(dependency required by "app-text/ghostscript-gpl-9.05-r1[cups]" [installed])
(dependency required by "net-print/foomatic-filters-4.0.15" [installed])
Sono disorientato. Io le USE gliele ho date, ma lui le chiede ancora? :?
EDIT:
Mi correggo. Anche il primo rigo è un pelo differente. Questa volta dice:
!!! The ebuild selected to satisfy "media-libs/mesa[egl]" has unmet requirements.
Ma per il resto è proprio uguale.
...mmm no!
Togli le use che hai aggiunto, riprova e posta il risultato.
Poi mostra:
cat /etc/make.conf
cat /etc/portage/package.keywords
cat /etc/portage/package.mask
cat /etc/portage/package.use
Ovviamente, è lo stesso della prima volta.
    xvmc? ( g3dvl )
darkstar / # cat /etc/make.conf
# These settings were set by the catalyst build script that automatically
# built this stage.
# Please consult /usr/share/portage/config/make.conf.example for a more
# detailed example.
CFLAGS="-march=native -O2 -pipe"
CXXFLAGS="${CFLAGS}"
# WARNING: Changing your CHOST is not something that should be done lightly.
# Please consult http://www.gentoo.org/doc/en/change-chost.xml before changing.
CHOST="x86_64-pc-linux-gnu"
# These are the USE flags that were used in addition to what is provided by the
# profile used for building.
USE="mmx sse sse2 X Xaw3d a52 aac aalib alsa ao bash-completion bcmath gtk xorg glibc-omitfp mpi smp cups custom-cflags \
custom-optimization custom-cpuopts xvmc gtk extras audiofile cairo cdda cddb cdparanoia cdr cgi cracklib cdr css cxx dbus \
dga djvu dri gdu device-mapper gd posix disk-partition automount icu ntfs fat thunar gpm gnome mysql sql webkit xulrunner \
kdrive dts dv dvb dvd dvdr eds encode evo exif axpat fastcgi ffmpeg fftw flac foomaticdb fortran gdbm policykit sqlite hddtemp gpm \
ggi gimp ginac gimp gnutls gphoto2 gps gsm gls graphviz gstreamer hal java jbig jpeg jpeg2k lame twolame libv4l libv4l2 libgda lock \
lzo matroska mng mp3 mp4 mpeg mtp mplayer musepack musicbrainz nas nptl openal ogg openexr openmp oss pch perl pda pcre pcntl \
pdf plasma posix png prelude ppds python pulseaudio qt4 raw scanner semantic-desktop session shorten smartcard sndfile speex spell ssl startup-notification svg \
svga tcl tk threads syslog subversion glib mpi-threads fuse theora udev v4l v4l2 vcd win32codecs vorbis wapack wmf x264 xcb xft \
xine xpm xv xvid optimized-qmake fontconfig imagemagick mjpeg floppy xrandr midi timidity curl libass libcaca vdr faac faad \
schroedinger glitz cleartype qt3support mono network static-libs opengl -mmxext -3dnow -3dnowext lm_sensors sip wav networkmanager \
dso php_targets_php5-2 embedded write zip zlib"
INPUT_DEVICES="mouse keyboard evdev"
VIDEO_CARDS="radeon"
MAKEOPTS="-j2"
ACCEPT_LICENSE="@EULA"
EMERGE_DEFAUL_OPTS="--autounmask=n"
LINGUAS="it"
darkstar / # cat /etc/portage/package.keywords
=app-portage/portato-0.14.1 ~amd64
=net-misc/r8168-8.028.00 ~amd64
=sci-libs/opencascade-6.5 ~amd64
=x11-themes/faenza-xfce-icon-theme-0.2.1 ~amd64
=x11-libs/libgxim-0.3.3 ~amd64
=app-i18n/imsettings-1.2.8.1 ~amd64
darkstar / # cat /etc/portage/package.mask
app-misc/lirc
net-nds/openldap
darkstar / # cat /etc/portage/package.use
dev-java/icedtea-bin -X -cups
x11-libs/gtk+ -cups
net-print/cups -java -ldap
dev-vcs/subversion -dso
dev-libs/cyrus-sasl -mysql
dev-util/cmake -qt4
x11-libs/qt-gui -cups
net-nds/openldap -sasl
x11-themes/tango-icon-theme zlib
Ok.
Aggiungi "g3dvl" alle USE in /etc/make.conf, poi riprova.
Mi sta scaricando 77 paccheti! :oO:
Ottimo.
xvmc? ( g3dvl )
significa:
"ho xvmc quindi ho attivi anche g3dlv oppure disattivi anche xvmc"
Ma xvmc era tra i rossi! Allora i rossi sono quelli che si hanno già?
Tutte queste legende non le so. :D
Però so di quella rappresentazione "use1? (use2)" e controllando in make.conf avevi, effettivamente, use1!
